Setting
Setting is an item that stores configuration properties of your project.
List of available settings
| Name | Default Value | Description |
| ACTIVE_SCENARIO | 0 | Currently active Scenario |
| AREA_GROUPS | Group Areas based on these Attribute names in Tygron Client | |
| AUTO_CALCULATION | false | When true indicators, panels and overlays are automatically recalculated on data changes |
| BASE_PANELS | HOVER_PANEL NAVIGATION_PANEL TOPBAR_PANEL LEFT_MENU_PANEL FEEDBACK_PANEL | Basic panels set (that are not triggered by special functionality) |
| CURRENCY | EURO | Project currency |
| DECIMALS | 6 | Decimal accuracy used in attributes and function values |
| DEFAULT_GEOPLUGINS | Default Geo Plugins in new Project Wizard | |
| DEFAULT_GROUNDPRICE_M2 | 400 | Default price of one m2 ground |
| DEFAULT_GROUND_LOWER_PRICE_M3 | 50 | Default price to lower one m3 ground |
| DEFAULT_GROUND_RAISE_PRICE_M3 | 50 | Default price to raise one m3 ground |
| DETAILED | true | High resolution project |
| EXPORT_CRS | EPSG:3857 | Default export CRS for polygon data in Tygron Client |
| GRID_CELL_SIZE_M | 2 | Overlay grid cell size in meters |
| IMPORT_CRS | Default import CRS for polygon data in Tygron Client | |
| IMPORT_CRS_FORCE_XY | true | Default import CRS (force XY) for polygon data in Tygron Client |
| ITERATIONS | 1 | Amount of Iterations during a recalculation update |
| KEEP_ALIVE | NEVER | Keep Project alive (active) base on this setting |
| LIMIT_MAP | MULTIPOLYGON EMPTY | Limits Project map generation and later calculation to this MultiPolygon |
| MAP_SIZE_M | 0 0 | Project map size in X (longitude) and Y (latitude) in meters |
| MAX_TOTAL_GRIDCELLS | 0 | Maximum amount of Overlay grid cells per Project |
| MEASUREMENT_SYSTEM_TYPE | SI | Unit system for Measurements |
| MIN_CELL_M | 0 | Minimum Overlay grid cell size in meters |
| MODEL_STYLE | TEXTURED | Model (buildings, bridges, tress, etc) style used for visualisation in Tygron Client |
| PROJECT_NAME | Project Name | Project name |
| RASTERIZATION | COMBINED | Selected rasterization method to convert polygon into the Overlay grid raster |
| RECALCULATION_REQUIRED | false | When true this indicates that a recalculation update is needed |
| RECENT_CRSS | EPSG:3857 EPSG:4326 | Recently used export CRS values in Tygron Client |
| REGION | NORTHWESTERN_EUROPE | Project Region: used to define the default functions |
| RESERVED_LAND | MULTIPOLYGON EMPTY | MultiPolygon for reserved land used in sale transations |
| SATELLITE_BRIGHTNESS | ||
| Satellite backgrounds can be dark, this values compensates for that in Tygron Client visualisation | ||
| SATELLITE_COLOR | Instead of Satellite imagery this color (RGBA) can be used for visualisation in Tygron Client | |
| SATELLITE_FILE_NAME | default | Name of the satellite background asset files |
| SCHEDULED_UPDATE | Scheduled Update moment in millis | |
| SCHEDULED_UPDATE_MAIL | When the Scheduled Update has finished email this address | |
| SCHEDULED_UPDATE_SMS | When the Scheduled Update has finished SMS this phone number | |
| SECTOR_SIZE_M | 500 | Height Sector tile size in meters |
| SHOW_ACTION_LOG | true | Show Action log panel in Tygron Client |
| SHOW_BUILDING_AND_MEASURE_POPUP | false | When a building is placed an interaction popup needs to be shown |
| SHOW_WATER_POPUP | false | When a waterway is placed an interaction popup (for the water authority) needs to be shown |
| SKY_TYPE | DEFAULT | Sky visualisation type in Tygron Client |
| SOLAR_PANEL_POSITION | 0.0 -0.5 -1.0 | Solar panel positioning used for visualisation in Tygron Client |
| STATE | NOTHING | Simulation Time State |
| SUN_DATES | Project sun dates used for Sun visualisation in Tygron Client | |
| SUPER_USER_MESSAGE | Super user message to all clients | |
| SUPPORT | PREMIUM | License support level |
| SURROUNDING_MAP_EXTEND_M | 0 0 | Surrounding map extend for visualisation of Sattelite and Elevation around Project map |
| TIMESTAMP_FORMAT | dd/MM HH:mm:ss | Timestamp format for exporting/importing date/time values in e.g. csv files |
| TIME_ZONE | Project timezone offset | |
| TRAFFIC_VISUAL_MULTIPLIER | 4.0 | Traffic visualisation multiplier in Tygron Client (not used in calculations) |
| WATER_HEIGHT | ||
| Average water elevation reference point used for visualisation in Tygron Client | ||
| WATER_TYPE | CANAL | Water visualisation type in Tygron Client |
| WEB_ALLOW_LOGIC_EVENT | true | Allow logic endpoint execution for Web Viewers |
| WEB_ALLOW_PARTICIPANT_EVENT | true | Allow participant endpoint execution for Web Viewers |
| WEB_ALLOW_QUERIES | false | |
| WEB_BASE_MAP | SATELLITE | Background type used Web Viewers |
| WEB_DEFAULT_APP | 2d | Default Web Viewer type (2D or 3D) |
| WEB_FRONT_PANEL | ||
| Open Web Viewers with this Panel ID instead of default map | ||
| WEB_MAP_CUSTOM_PANEL | ||
| WEB_MODEL_SHADOW | true | 3D Web Viewer shadow visualisation enabled |
| WEB_MODEL_SPACING | 2.0 | 3D Web Viewer model spacing, distance between e.g. trees |
| WEB_MODEL_STYLE | WHITE | Web Viewer Model style (COLORED or WHITE) |
| WEB_MODEL_TEXTURE | MEDIUM | 3D Web Viewer texture quality/size (SMALL, MEDIUM, LARGE) |
| WIND_DIRECTION | 135 | Wind direction angle in degrees |
| WIND_SPEED_M_PER_S | 5.0 | Wind speed in meters per second |
| WIZARD_TIME_MINUTES | ||
| Project map generation time in minutes | ||
| WORLD_REFERENCE_POINT | 0 0 | World reference point (upper left corner) used to convert local coordinates to EPSG 3857 world coordinates |
API Endpoints
