GridSpatial
Revision as of 14:34, 21 April 2026 by Frank@tygron.nl (talk | contribs)
File:Grid measure with buildings.png
Activated measure with a GridSpatial and several buildings on top.
A GridSpatial is a component of a Measure that stores spatial information on how to apply a set of Grids to the DTM when the measure is activated. The area to which the Grids are applied can be restricted by specifying a MultiPolygon to the GridSpatial.
This MultiPolygon can either be:
  • Calculated automatically based on the configured Grids for that GridSpatial.
  • Configured manually by supplying a MultiPolygon, for example by drawing or importing.
  • You can add more than one Grid to a GridSpatial of a Measure.
  • You can manually provide a MultiPolygon to specify where the Grids are applied.
  • GridSpatials are applied in the order at which they were added to a Measure.
  • No data values in a Grid are never applied to the DTM.
  • The specified Grid Overlays must be set to inactive, otherwise the Measure cannot be applied.
