Api session event editor building
Revision as of 11:23, 10 April 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor building Events.
API Endpoints for Building editing.
Name Description
add Add new Building
add_polygons Add polygons for Building Section. In case the Building is empty, optionally set ownership to largest Plot Owner of provided MultiPolygon
append_attribute Appended to existing Building attribute value
duplicate Duplicate existing Building
import Import Building Collection
remove Remove existing Building
remove_attribute Remove attribute from Building
remove_polygons Delete polygons for Building Section
set_attribute Set Building attribute value
set_attributes Set multiple Building attribute values
set_name Set new name of existing Building
Additional API Endpoints:
Name Description
add_geometry Add a custom Building geometry
add_road Add Road
add_section Add Section
add_standard Add Standard
add_underground Add Underground
duplicate_section Duplicate a Building Section.
generate_rotation_angles Calculation a rotation angle for Building having the identifying attribute polygons, optionally only for specified Building.
generate_water_connection Generate Water Connection.
multi_select Multi Select
query Executes a single TQL query. Note: you can also use the session/query endpoint to execute multiple statements and get additional information on API usage.
remove_geometries Remove all custom Building geometries
remove_sections Remove Sections
reset_category_values Reset Category Values
reset_function_values Reset Function Values
reset_slanting_roof_height Reset Height of the Slanting Roof of a Building section
set_category_value Set Category Value
set_decals Set Decals
set_floors Change amount of floors
set_function Set Function
set_function_value Set Function Value
set_owner Set Owner
set_slanting_roof_height Change Height of the Slanting Roof of a Building section
Deprecated API Endpoints:
Name Description
duplicate_sections Use DUPLICATE_SECTION instead for identical result.
