Api session event editor building
API api session event editor building Events.
Building editing.
| Name | Description |
| ADD | Add new Building |
| ADD_POLYGONS | Add polygons for Building Section. In case the building is empty, optionally set ownership to largest Plot Owner of provided MultiPolygon |
| APPEND_ATTRIBUTE | Appended to existing Building attribute value |
| DUPLICATE | Duplicate existing Building |
| IMPORT | Import Building Collection |
| REMOVE | Remove existing Building |
| REMOVE_ATTRIBUTE | Remove attribute from Building |
| REMOVE_POLYGONS | Delete polygons for Building Section |
| SET_ATTRIBUTE | Set Building attribute value |
| SET_ATTRIBUTES | Set multiple Building attribute values |
| SET_NAME | Set new name of existing Building |
Specific Events:
| ADD_GEOMETRY | Add a custom building geometry |
| ADD_ROAD | Add Road |
| ADD_SECTION | Add Section |
| ADD_STANDARD | Add Standard |
| ADD_UNDERGROUND | Add Underground |
| DUPLICATE_SECTION | Duplicate a Building Section. |
| GENERATE_ROTATION_ANGLES | Calculation a rotation angle for buildings having the identifying attribute polygons, optionally only for specified buildings. |
| GENERATE_WATER_CONNECTION | Generate Water Connection. |
| MULTI_SELECT | Multi Select |
| QUERY | Executes a single TQL query. Note: you can also use the session/query endpoint to execute multiple statements and get additional information on API usage. |
| REMOVE_GEOMETRIES | Remove all custom building geometries |
| REMOVE_SECTIONS | Remove Sections |
| RESET_CATEGORY_VALUES | Reset Category Values |
| RESET_FUNCTION_VALUES | Reset Function Values |
| RESET_SLANTING_ROOF_HEIGHT | Reset height of the slanting roof of a building section |
| SET_CATEGORY_VALUE | Set Category Value |
| SET_DECALS | Set Decals |
| SET_FLOORS | Change amount of floors |
| SET_FUNCTION | Set Function |
| SET_FUNCTION_VALUE | Set Function Value |
| SET_OWNER | Set Owner |
| SET_SLANTING_ROOF_HEIGHT | Change height of the slanting roof of a building section |
Deprecated Events:
| DUPLICATE_SECTIONS | Use DUPLICATE_SECTION instead for identical result. |
