Api session event editor area
Revision as of 08:38, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API api session event editor area Events. Area editing. {|class=wikitable !Name !Description |- |ADD |Add new Area |- |ADD_POLYGONS |Add polygons to existing Area |- |APPEND_ATTRIBUTE |Appended to existing Area attribute value |- |DUPLICATE |Duplicate existing Area |- |api session event edit...")
Area editing.
Name Description
ADD Add new Area
ADD_POLYGONS Add polygons to existing Area
APPEND_ATTRIBUTE Appended to existing Area attribute value
DUPLICATE Duplicate existing Area
IMPORT Import Area Collection
REMOVE Remove existing Area
REMOVE_ATTRIBUTE Remove attribute from Area
REMOVE_POLYGONS Remove polygons from existing Area
SET_ACTIVE Set Area active
SET_ATTRIBUTE Set Area attribute value
SET_ATTRIBUTES Set multiple Area attribute values
SET_COLOR Set new color of existing Area
SET_NAME Set new name of existing Area
Specific Events:
Name Description
ADD_GROUP Add Group
ADD_RELATION Add Relation
ADD_WITH_ATTRIBUTE Add With Attribute
GENERATE_BORDER_AREAS Generate Border Areas
GENERATE_INUNDATION_AREAS Generate Inundation Areas
GENERATE_SEWER_AREAS Generate Sewer Areas
GENERATE_WATER_AREAS Generate Water Areas
REMOVE_ALL_ATTRIBUTES Remove All Attributes
REMOVE_GROUP Remove Group
REMOVE_RELATIONS Remove Relations
SET_POLYGONS Set Polygons
SET_RELATION Set Relation
Deprecated Events:
Name Description
REMOVE_FILTER Use REMOVE_GROUP instead for identical result.
