Solid (Water Overlay)
Revision as of 16:07, 17 January 2023 by Frank@tygron.nl (talk | contribs) (Created page with "{{building attributes | <onlyinclude> {{building attributes|type=row|group=Water Overlay |attribute=SOLID |unit={{boolean}} |functionvalue=SOLID |description=Whether the building is solid and blocks water flow or not. |icon= }} </onlyinclude> }} Buildings which are SOLID block water flow up to the height defined by the overlay model attribute DESIGN_FLOOD_ELEVATION_M. This attribute can be useful to adjust functions for...")
Buildings which are SOLID block water flow up to the height defined by the overlay model attribute DESIGN_FLOOD_ELEVATION_M. This attribute can be useful to adjust functions for which water should be allowed to flow through, for example garden hedges.
