Special Effect
Revision as of 11:33, 27 May 2021 by Rudolf@tygron.nl (talk | contribs) (→Available special effects)
This article is a stub.
What are Special Effects
Special Effects are effects that can be added to a model to make it more realistic. They are visual additions to the 3D world.
How Special Effects relate to the Tygron Platform
Special Effects can be added to the 3D world to create a more realistic project.
The Special Effects menu can be found in the Current situation tab:
The following special effects are available:
| Name | Description | Environment |
| Chimney Smoke (Large) | A thick, near opaque smoke as from an uncontrolled fire. | |
| Chimney Smoke (Medium) | A some effect as from an oversized bonfire. | |
| Chimney Smoke (Small) | A smoke effect akin to a smoldering object on the ground. | |
| Explosion | A small, periodic, shooting flash. | |
| Light (Red) | A flashing red light. | |
| Light (Yellow) | A constant downward illumination, such as for a streetlight. | |
| Oil Flames | A continuous fire effect with some smoke. | |
| Shockwave | Red concentric circles continuously emanating from a central point in a flashing fashion. |
