How to use the Water Connection Generator to generate Buildings
With the Water Connection Generator it's possible to automatically generate additional Buildings for the water system in a Project.
Editor → Current Situation (Ribbon tab) → Buildings (Ribbon bar) → Generate Water Connections (Dropdown)
How to use the Water Connection Generator to generate Buildings:
- In the "function" drop-down, select the Function for the Buildings which you want to generate.
- In the "applied on" drop-down, select whether to generate Buildings on the entire map, only near the current viewpoint, or in a specific Neighborhood.
- For the width, enter the width the Building should have for use in calculation models such as the Water Overlay.
- If water bodies should have connections generated for them as well (rather than just waterways), select "include water bodies".
- Select "OK" to generate the Buildings.
1. Go to Buildings -> Generate Water Connections
2. Water Connections dialogue
3. Generated Buildings (Culverts in this example)
- Generated Buildings will have their respective width Attribute set to the value configured. This applies only to Functions with an associated width-like Attribute used in calculation models. For example, a Culvert has a CULVERT_DIAMETER Attribute to set.
- Defaults provide acceptable results in most cases; use advanced options to fine-tune the algorithm for specific project needs.
- How to use the Water Connection Generator with advanced options to generate Buildings
- How to remove Buildings generated by the Water Connection Generator
