How to remove Buildings generated by the Water Connection Generator
To adjust the results from the Water Connection Generator, you can automatically remove all Buildings of a specific type from the project area and try again.
Editor → Current Situation (Ribbon tab) → Buildings (Ribbon bar) → Generate Water Connections (Dropdown)
How to remove Buildings generated by the Water Connection Generator.:
  1. In the "function" dropdown, select the Function of which you want to remove all Buildings.
  2. In the "Applied on" dropdown, select whether to remove Buildings from the entire map, only near the current viewpoint, or from a specific Neighborhood.
  3. Select "Remove Generated" to remove the Buildings.
