Foliage crown factor (Heat Stress Overlay)
(Redirected from Foliage crown factor (Heat Overlay))
| Icon | Attribute | Unit | Range | Description |
| FOLIAGE_CROWN_FACTOR | ratio | The ratio between the diameter of the foliage and the height of tree trunks. |
The foliage crown factor is used to calculate the extent of foliage, which can influence the calculation of the sky view and the shade. The height of the Building multiplied by the crown factor yields the diameter of the foliage.
The crown factor is used because the extent of foliage itself is not generally available as geographical open data. Instead, often only the extent of tree trunks is provided.
- Foliage can be calculated based on the FOLIAGE_CROWN_FACTOR. This calculation can be superseded when the Heat Stress Overlay (set to use the DPRA Heat Stress Module) is configured to use either Areas or a GeoTIFF to determine foliage height. In those cases the FOLIAGE_CROWN_FACTOR of Buildings is unused.
API Endpoints
