Dates (Heat Stress Overlay)
(Redirected from Dates (Heat Overlay))
  • It is recommended to use the Heat Stress Overlay Wizard to generate and edit the dates.
  • The sun altitude and sun azimuth are automatically recalculated based on project location and date only when using the Heat Stress Overlay configuration wizard, not when modifying the attribute directly.
  • The dates are stored as milliseconds past the defined epoch. Care should be taken when manually adjusting these numbers!
API Endpoints
