How to add and remove an Attribute
Revision as of 09:54, 18 November 2026 by Server@tygron.com (talk | contribs)
Attributes can be added to features such as Buildings, Stakeholders, Indicators, Areas and Overlays.
Attribute management is generally consistent, though some features require additional assets (e.g., indicators or terrains). Refer to the feature's main article for details.
Adding an Attribute
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to add an Attribute:
  1. Select the feature you want to add an attribute to
  2. Select the Attribute tab on the right side
  3. Enter a name/ value pair for the new Attribute
  4. Select 'Save New Attribute'
  5. Notice the new attribute is added to the feature
Removing an Attribute
How to remove an Attribute:
  1. Select the feature you want to remove the attribute from
  3. Select 'remove' next to the Attribute you would like to remove
  4. Notice the Attribute is removed
Removing all Attributes
To reset all attributes at once, select 'Reset Attributes' in the bottom corner on the right side.
Reset Attributes Button
API Endpoints
