How to manually configure a Water Overlay
When first added to the project, each variant of the water overlay will be created with a default configuration which will allow for an initial calculation to take place and results to display. Additional data can be added and settings and parameters of the overlay can be tweaked for specific use-cases. This will improve the accuracy and relevancy of the overlay. It is possible to configure the parameters manually, or by using the configuration wizard. A few settings can only be changed manually. Besides the data of geographical features, which have their own means of loading in depending on their type, all manual configuration options are listed here.
Grid cell size configuration
- Main article: Grid overlay
Like all grid overlays, the water overlays have a number of configuration options related to their general method of calculation. Most notably, it is possible to configure the cell size on which the calculations occur.
- Main section: Calculation preference
The calculation preference indicates the level of accuracy the calculations should be performed with. Depending on the configuration timesteps will be calculated more conservatively. This affects the time it takes to perform the full calculation, and the exact quantities of water moving between cells.
- Main section: Weather
Weather configuration—including simulation duration, rainfall, and evaporation rate—is managed via a separate weather object connected to the water overlay. The weather object can be replaced with another, changing the main simulation and weather properties. The weather itself can be changed as well.
In the weather object's "Simulation" tab, you can configure weather using either a simple linear setup or a complex sequence of values. The complex setup can be created by loading in a CSV (comma separated values) file. By switching to the attributes tab of the weather object, the same properties can be adjusted by directly modifying the attributes.
Ground water configuration
- Main section: Ground water
A ground water GeoTIFF can be loaded in to prepopulate the underground with water in the form of a saturated zone. This is only a relevant configuration when the ground water mode is set to "Complete". A ground water GeoTIFF is optional. If no ground water tiff is selected, the assumed ground water level is equal to the WATER_LEVEL of the water area.
The presence of a ground water GeoTIFF can be toggled by checking or unchecking the "Include ground water tiff" checkbox. When checked, a number of GeoTIFFs are available for ground water levels by default. Other GeoTIFFs for groundwater levels can also be loaded in by clicking on "Select GeoTIFF".
Subsidence configuration
- Main section: Subsidence
It's possible to connect the water overlay to a subsidence overlay, if one exists in the project. The result of the subsidence calculation, specifically the amount the terrain has lowered, is applied to the terrain height at the start of the water model's simulation. A connection to a subsidence overlay is optional. If no subsidence overlay is connected, the terrain height is not adjusted in this fashion.
- Main section: System visualization
The water overlay simulates detailed flow, with specific features performing specialized hydrological functions. These features include the sewers and the hydrological buildings. This flow can be visualized as a graph overlaid on the water overlay.
Active in simulation setting
Like all grid overlays, the water overlays can be configured to either an active or inactive state. This avoids unnecessary recalculations and computational overhead when viewing existing results during project changes.
Result type configuration
- Main section: Result type
The water model performs a complete simulation in which water flows through the project area. Depending on the use-case, only a specific type of output resulting from the simulation may be required. The result type of the water overlay indicates exactly what kind of data is recorded and outputted.
Note that via the configuration wizard multiple result types can be added in parallel in the form of result child overlays.
Legend configuration
Depending on the selected result type, the output created by the water overlay is interpreted in different ways. The raw data calculated is assigned colors based on the configured legend. Each result type has an assigned default legend which helps with interpreting the output. Default legends are provided, but these can be modified to fit specific meanings or result ranges.
Keys configuration
- Main section: Keys
The water model's calculations rely on a number of areas and buildings for their input data. Hydrological features and hydrological buildings have special meanings in terms of policy or scenario. Attributes can be redefined to ensure compatibility with external data or to support parallel calculations for different scenarios. This would allow two instances of a water overlay to work with the same dataset but with different configurations for hydrological features or buildings.
The exact attributes the overlay uses as input from hydrological features and buildings can be changed on the "Keys" tab, by using the relevant dropdown to change the attribute name to the desired attribute.
Keys
The water model makes use of data present in geographical features in the project. This data is used as input for the various calculations which together model the water flow. The water model recognizes what attributes of geographical features form the parameters required for the calculation through key definitions. Each key is the name of an attribute which the water model should use to determine a specific parameter.
Keys are set to default attribute names, which apply to hydrological features, hydrological buildings, and hydrological properties of terrain. Keys can be changed so that imported data can be interpreted without renaming attributes, or to allow different configurations to come forth from the same dataset.
Attributes configuration
- Main section: Attributes
The water model's calculations make use of a number of centralized parameters, which are configured as attributes of the overlay. Default parameters vary by water overlay variant to better suit specific calculation types. Parameters can be tweaked further to fit specific use-cases; otherwise, default values are used.
