XA (TQL)
Revision as of 09:40, 14 October 2026 by Frank@tygron.nl (talk | contribs)
The 'XA' clause value is a variation on the 'X' clause value. The characters 'XA' should be followed by an underscore and the name of an Attribute; for example XA_MONUMENTAL.
The result of using 'XA' for the clause value, is the automatic creation of multiple TQL statements, one with each Item ID for that Clause Parameter that can be found in the project data. Items are only taken into account if they have a non-zero value for the specified attribute.
Internally, the resulting TQL statements are placed in a single array; Similarly the result will be an array of TQL results.
Example
Consider the following (simplified) Building GeoJSON data of a project:
 { "id" : 0, "name" : "Lindelaan 3", "attributes": { "MONUMENTAL" : [0.0], "MEASURED_M2" : [200.0] } },
 { "id" : 1, "name" : "Kerklaan 40", "attributes": { "MONUMENTAL" : [1.0] } },
 { "id" : 2, "name" : "Achterweg 7", "attributes": { "MONUMENTAL" : [-3.5] } },
 { "id" : 3, "name" : "Achterweg 9", "attributes": { } },
 { "id" : 4, "name" : "Kerklaan 61", "attributes": { "MONUMENTAL" : [2.0]},
 { "id" : 5, "name" : "Duiker 1235", "attributes": { "CULVERT_DIAMETER" : [1.0]}
The TQL statement to obtain the names of the monumental Buildings is:
SELECT_NAME_WHERE_BUILDING_IS_XA_MONUMENTAL
which internally is replaced with a list of TQL statements, separated by a comma:
SELECT_NAME_WHERE_BUILDING_IS_1, SELECT_NAME_WHERE_BUILDING_IS_2, SELECT_NAME_WHERE_BUILDING_IS_4
Its result will be a list of names, separated by comma's:
"Kerklaan 40", "Achterweg 7", "Kerklaan 61"
Similarly, the TQL statement to obtain the monumental value of monumental Buildings is:
SELECT_ATTRIBUTE_WHERE_BUILDING_IS_XA_MONUMENTAL_AND_NAME_IS_MONUMENTAL
Its result will be a list of values, separated by a comma:
1.0, -3.5, 2.0
Clause Parameters
The XA value can be used in the following TQL Clause parameters:
  • The following variants on XA exist:
    • XCA: A combination between XC and XA.
API Endpoints
