CSW
A CSW, Catalog Service for the Web, is an online Catalog standard for searching datasets. Users can provide keywords to search on. All the datasets that contain the keyword in their metadata will pop up. A dataset can then be inspected and downloaded in different (geo) data formats. The CSW standard is defined by the OGC, the Open Geospatial Consortium.
How to edit or remove a CSW URL
Editing a Source URL.
How to edit a CSW Connection:
  1. Select in the editor Current situation
  2. Hover over 'Geo Import' from the ribbon bar
  3. Select 'Show Project Sources'
  4. Select the desired connection you wish to edit
  5. In the panel on the right, edit the name, URL, Uploader and/or description
Removing a Source.
Removing a Source.
How to remove a CSW Connection:
  4. Select the desired connection you wish to remove
  5. Click on the button 'Remove' at the bottom left corner
