Api session event editor source add catalog
API Endpoint: api/session/event/editorsource/add_catalog/
Description: Add a new Catalog Source, given a Geo Catalog Type, Name and URL
0 REQUIRED (Enumeration) Geo Catalog Type CSW or ESRI
1 REQUIRED (String) Name
2 REQUIRED (String) URL
200 Integer (Catalog Source ID)
curl 'https://engine.tygron.com/api/session/event/editorsource/add_catalog/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "CSW", "Name", "URL" ]'
JavaScript example POST
 body: '[ "CSW", "Name", "URL" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/add_catalog/", options)
