Api session event editor netline
Revision as of 15:23, 30 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetline/
API Endpoints for Net Line editing.
Name Description
add Add a Net Line with the provided Net Function
append_attribute Appended to existing Net Line numeric Attribute value
remove Remove Net Lines
remove_attribute Remove the specified Attributes for each specified Net Line
set_attribute For each Net Line, set a particular Attribute to a specified array of values, optionally providing its Source.
set_attributes Set multiple Net Line numeric Attribute values
Additional API Endpoints:
Name Description
add_for_points Connect start and end Points with one or more Net Lines of a specified Net Function. Nodes are created for both Points. Optionally connect the Points using the road system and specify the merge distance for existing Nodes.
insert_and_add_for_points Insert one Point into the first Net Line and a second Point into the Second Net Line and potentially connect these two Points with a new Net Line with a specified Net Function. Nodes are created for start and end Point. Optionally connection the two Points using the road system. Also specify at what distance the new Nodes are merged with existing Nodes.
insert_point Insert a new Node in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Nodes are merged with existing Nodes.
move_and_insert Place an existing Node at a new location and insert it in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Nodes are merged with existing Nodes.
remove_all_attributes Remove all Attributes for each specified Net Line
remove_repeated Remove Net Lines and optionally remove connected Net Nodes linked to only one other Net Line of the same Net Type.
set_net_function Set the Net Function for a Net Line
