How to create AI training data with QGIS
In this how-to, we will use Areas to store our data. Areas can overlap and be grouped together using a particular attribute, in this case FOLIAGE. The FOLIAGE attribute should contain a single integer number, which represents the classification. For example, we can use the following classification:
- Deciduous Tree
- Pine Tree
- Heath area
- Hedge
- Bush
- Reed
- Flower bed
- Leafless Tree Area
The areas are drawn on top of a particular Overlay or WMS Layer of your project. In this case we will use the original satellite background layer of a Project's WMS service.
How to create AI training data with QGIS:
Setup a Project with an attribute Area and copy the WFS link
How to Setup a Project with an attribute Area and copy the WFS link:
- Open your project in editor mode.
- Hover over Areas in the ribbon bar, and select Add new Empty Area.
- With the Area selected, select the Attribute tab in the Area Detail Panel.
- Under Add new Attribute, type FOLIAGE for name and 1 for value.
- Click Save New Attribute to add the FOLIAGE attribute.
- Click on the Group by Attribute button in the Area Overview Panel.
- Add the same Attribute name as added for the Area in the previous steps.
- Next, hover over Areas in the ribbon bar and select Export Geo Data
- For Filter, select FOLIAGE
- Select any of the GeoJSON options.
- Click on the Copy the URL button next to Web Feature Service (WFS)
Setup QGIS with a Project's Area WFS and a Satellite Background
How to Setup QGIS with a Project's Area WFS and a Satellite Background:
- Open QGIS
- In QGIS, Hover over Layer in the ribbon bar, and under add new Layer, select add WFS / OGC API Feature Layer
- In the Data Source Manager panel, select New.
- Paste the copied WFS URL from the Export Geo Data panel into the URL field.
- Provide an appropriate name, for example Foliage - My Project Name and confirm.
- Click on the Connect button.
- Select the layer named Foliage Areas and click on Add.
- In the Tygron Application again, hover over Overlays and select Export Grid Data
- Click on the Copy URL button
- In QGIS, hover over Layer again, and under add new Layer, select add WMS/WMTS.
- Click on add new.
- For the URL field, paste the copied Web Map Service (WMS) URL.
- For the name, write Satellite - My Project Name and click on OK to confirm.
- Click on connect and select the layer named SATELLITE ORIGINAL and click add.
- In the Layers panel in QGIS, drag and drop the Foliage Layer above the Satellite Layer.
Add a WFS Layer of your project session in QGIS.
Add a WFS Connection of your project session in QGIS.
Connect to the WFS and select the Foliage Area layer.
Add a WMS Layer of your project session in QGIS.
Add a WMS Connection of your project session in QGIS.
Connect to the WMS and select the Satellite Original layer.
Setup the QGIS WFS Layer with a classification and attribute form
How to Setup the QGIS WFS Layer with a classification and attribute form:
- Right click on the Foliage Areas Layer, and select Properties
- In the Layer's Properties Panel, select the Symbology Tab.
- Change the type to Categorized.
- Use the plus button to add one category per class, plus one additional entry.
- Per type, do the following:
- Add an entry and provide it with a floating point number, such as 1.0.
- Select a color
- Provide the name of the entry with the classification, for example Deciduous.
- Finally, add an Other entry with no value and a distinct color (e.g., pink or purple).
- Click on the apply button.
- Next select the tab Attributes Form
- Change the option to Drag and Drop Editor.
- Under form Layout, remove all fields except the FOLIAGE field.
- Select the FOLIAGE field, and under general, select the Reuse last entered value option.
- Change the Text Field widget to Classification.
- Select apply to confirm.
Configured symbology using the categorized option.
Widget Type set to Classification.
Optionally save the style to a QML file.
Edit the WFS layer, add features and save changes
How to Edit the WFS layer and add and edit features and saving the changes:
- Select the WFS layer in the layer panel.
- Select the Pencil option named Toggle Editing
- To add new Features, select the Polygon Start button
- Left click on the 2D View to add vertices
- Right click to confirm the shape. The feature form appears.
- Provide the correct value and click on the OK button. You can also confirm by pressing the ENTER key, and cancel with ESC.
- To edit a feature's vertices, select the Vertex Tool button
- To edit a feature's form, activate a Feature Select Option (yellow icons), select the features, and click the pencil icon.
- Delete a feature by removing all its vertices with the Vertex Tool; changes apply after saving.
- To save all changes made to the WFS Layer, click on the save button. This sends all changes to the session on the Tygron Platform.
- Optional: Toggle the magnet option when vertices should touch and tweak the pixel distance accordingly.
Edit button in QGIS
Polygon Start button for adding new features.
Adding a feature by clicking in the 2D View.
Confirming a new feature with the attribute form.
Alternative attribute form using the Classification widget.
Vertex button in QGIS.
Feature selection buttons in QGIS.
Form button in QGIS.
Click the Save button to send local changes to the session on the Tygron Platform.
Magnet button in QGIS.
- You can only access and edit a WFS service of a session that is active on the Tygron Platform.
- Change the WFS Feature Layer's Attribute Form to 'Classification' if numeric values are difficult to remember.
- We recommend saving the WFS Layer style to a QML file via the Layer Properties panel to preserve legends and forms.
