How to add an Area to a Measure
Some calculations, such as the Travel Distance Overlay, require data in the form of Areas. To make these areas dynamic for Future Designs—where an area exists only when a specific Measure is active—specific setup is required.
How to activate and deactivate an Area together with a Measure:
- First make sure you have added or imported Areas that you want to (de)activate.
- In Future Design, open the list of Measures.
- Select the Measure which should (de)activate the Area(s).
- In the right panel, select the tab "Areas".
- Click on the "Add" button.
- Select the areas that you want to (de)activate. Optionally filter on name.
- Click on OK to confirm. The (de)activated areas should now be added to the measure.
