Global panel
Revision as of 11:40, 7 July 2026 by Frank@tygron.nl (talk | contribs)
The Global panel appears when opening a Global Panel item. It can be used to adjust globals' values during a session. These globals can be used to adjust TQL results for indicators or formula results for Combo Overlays present in the project.
The global's values are only changed by the Stakeholder when they press the Send button.
Global panel with two adjustable globals that is opened by clicking on the popup in the 3D Visualization. The popup belongs to the Global Panel.
