Select active (TQL)
Revision as of 12:32, 6 July 2026 by Frank@tygron.nl (talk | contribs)
Allowed clause parameters
Examples
  • SELECT_ACTIVE_WHERE_AREA_IS_5
Returns whether the Area with Item ID 5 is considered active; I.e. the area has an ACTIVE Attribute that has a value that is larger than 0.
  • SELECT_ACTIVE_WHERE_NET_TYPE_IS_ELECTRICITY
Returns whether the Net Setting ELECTRICITY_ACTIVE is considered active; I.e. the setting has a value of true.
API Endpoints
