Api session event editor netload
Revision as of 13:01, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetload/
API endpoints for Net Load editing.
Name Description
add Add new Net Load
append_attribute Appended to existing Net Load numeric Attribute value
import Import multiple Net Loads
remove Remove existing Net Load
remove_attribute Remove numeric Attribute from Net Load
set_attribute Set Net Load numeric Attribute value
set_attributes Set multiple Net Load numeric Attribute values
set_name Set new name of existing Net Load
Additional API endpoints:
Name Description
add_address Add Address
add_and_set_node Add And Set Node
generate_loads Generate Loads
generate_loads_and_paths Generate Loads And Paths
generate_paths Generate Paths
import_net Import Net
remove_address Remove Address
remove_all_attributes Remove All Attributes
remove_building Remove Building
remove_node Remove Node
set_building Set Building
set_net_type Set Net Type
set_node Set Node
set_point Set Point
set_state Set State
