Api session event editor netload
Api session event editor netload Endpoints.
API endpoints for Net Load editing.
| Name | Description |
| add | Add new Net Load |
| append_attribute | Appended to existing Net Load Attribute value |
| import | Import multiple Net Loads |
| remove | Remove existing Net Load |
| remove_attribute | Remove Attribute from Net Load |
| set_attribute | Set Net Load Attribute value |
| set_attributes | Set multiple Net Load Attribute values |
| set_name | Set new name of existing Net Load |
Additional API endpoints:
| add_address | Add Address |
| add_and_set_node | Add And Set Node |
| generate_loads | Generate Loads |
| generate_loads_and_paths | Generate Loads And Paths |
| generate_paths | Generate Paths |
| import_net | Import Net |
| remove_address | Remove Address |
| remove_all_attributes | Remove All Attributes |
| remove_building | Remove Building |
| remove_node | Remove Node |
| set_building | Set Building |
| set_net_type | Set Net Type |
| set_node | Set Node |
| set_point | Set Point |
| set_state | Set State |
