Api session event editor netload
Revision as of 14:15, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API api session event editor netload Events.
NetLoad editing.
Name Description
ADD Add new Net Load
APPEND_ATTRIBUTE Appended to existing Net Load attribute value
IMPORT Import multiple Net Loads
REMOVE Remove existing Net Load
REMOVE_ATTRIBUTE Remove attribute from Net Load
SET_ATTRIBUTE Set Net Load attribute value
SET_ATTRIBUTES Set multiple Net Load attribute values
SET_NAME Set new name of existing Net Load
Specific Events:
Name Description
ADD_ADDRESS Add Address
ADD_AND_SET_NODE Add And Set Node
GENERATE_LOADS Generate Loads
GENERATE_LOADS_AND_PATHS Generate Loads And Paths
GENERATE_PATHS Generate Paths
IMPORT_NET Import Net
REMOVE_ADDRESS Remove Address
REMOVE_ALL_ATTRIBUTES Remove All Attributes
REMOVE_BUILDING Remove Building
REMOVE_NODE Remove Node
SET_BUILDING Set Building
SET_NET_TYPE Set Net Type
SET_NODE Set Node
SET_POINT Set Point
SET_STATE Set State
