Demo Training Data Project
The Demo Train Dataset project is available for all users and can be found in the main menu under Edit projects. This project does not count towards your license.
This project is intended for people who are working in fields such as AI, remote sensing, data analysis, and urban planning.
This project showcases a method in the Tygron Platform to export a dataset for training a Mask R-CNN model..
The demo is a working project in which a number of areas are drawn, using a satellite overlay as underlay. These areas are marked with specific attributes, making it easy to export them as a training or test set using an export option in the Tygron Platform.
Project's content
Demo Train Dataset is a project that contains shapes of foliage, drawn as areas on top of a Satellite Overlay. These areas, in combination with satellite images, can be exported as a dataset for training a Mask R-CNN model. Such a model can then be applied to a different project location to detect foliage. A specific use-case is detecting foliage on private property, such as gardens and private yards.
Individual foliage areas
Satellite Overlay serving as input for images
AI Training Data
In order to train a Mask R-CNN model, we need to obtain two datasets, one for training and one for testing. A dataset consists of a list of numbered files, with the number representing the data entry number. Each data entry consists of the following files:
- An input image, as a PNG
- A mask image, as a PNG, containing gray values, where each gray value represents a unique identifiable feature.
- A label text file containing the classes of the identifiable features, where each class is identified with an integer number (larger than 0).
- Optional: A text file containing the bounding-box pixel numbers; min x, min y, max x, max y, for each identifiable feature in the input image.
Input image, in this case an image exported using the Satellite Overlay
Mask image with each unique feature identified by a gray value.
Class labels
Bounding box coordinates
The Tygron Platform allows users to export datasets. The Demo Train Dataset Project is set up to contain two separate sets of Areas to export; One set of Areas with the attribute TRAIN_FOLIAGE and one with the attribute TEST_FOLIAGE. Each set can be exported with an Overlay. Since both sets are drawn based on a Satellite Overlay named Original Satellite, we will use that Overlay.
Export a dataset
This how-to explains how to generate an AI Training Data using the Tygron Platform. This data can be used to train your own AI model.
This how-to explains how to generate AI training data using the Tygron Platform. This data can be used to train your own AI model.
- Open a project in editor mode using the Tygron Client
- Optionally add a Satellite Overlay. This overlay will be used to export train images for the dataset.
- Determine which [item] type will be used to export the dataset. For example Foliage areas drawn on top of the satellite overlay.
- Select the Export Geo Data option in the Ribbon bar popup of the selected item type. For example: Hover over Areas and select Export Geo Data
- Under Format, select the option AI Training Data PNG
- Filter items with an attribute, such as FOLIAGE
- Optionally select a prepared Intersection Area, for example a TRAIN_LIMIT_AREA.
- For the Overlay, select the preferred Overlay, for example the Satellite Overlay.
- The image size can be increased, as long as the amount of expected features within the image does not exceed the maximum amount of 250.
- The stride can be kept at 50%
- Click on the Export Files button
- Select a suitable folder for the generated dataset.
- Wait until the dataset is fully generated.
Configuration of the Export AI Training Data as PNGs for Foliage Areas on a Satellite Overlay, with an intersecting area.
- In case the export folder is not empty, a confirmation popup will appear on overriding the existing image, label, mask and bounding box files.
- In case a region intersects the limit area, but does not contain any features, it is still exported as a dataset-entry (image-, label-, mask- and bbox-file) but without labels, mask pixels or bounding box entries.
- In case the feature density is low, the image size can be increased.
- In case the feature sizes are small compared to the image size, the stride can be increased.
- A dataset can also be generated as AI Training Data CSV, which allows users to directly train on float matrices instead of color images.
- When the intended background image is not the satellite image provided by default but some other image or set of data, it is also possible to select a WMS Overlay referencing an external map service, or a Combo Overlay, using its
COLORfunction to compute a custom image.
Export Considerations
There are several considerations when exporting AI Training Data:
- The exported features (Buildings, Areas, etc) should match the overlay that these are exported with.
- A Larger image size leads to less inference calls by the Inference Model and therefore a faster calculation. However, the maximum amount of identifiable features within images of the train dataset may not exceed 250.
- The stride fraction can be configured to create more images and ensures features are fully inside certain images and not only on image borders.
Train your own model
A Tygron AI Suite[1] is available at github. This repository contains the necessary files to configure a Conda environment to train a new Mask R-CNN AI model.
Conda-forge's Miniforge[2] will be used to manage a Conda environments and run Jupyter Notebooks with python.
Example notebooks[3] provided in the repository can be used as a basis to train your own model.
TygronAI yml-file[4] provided in the repository can be used initialize a Conda Environment. It includes Pytorch and Jupyter Notebook.
- If you are not familiar with github, you can download the zip containing all the files that you need. Otherwise, clone the git repository
- Optionally unzip and open the folder containing the downloaded files; the local repository. Copy the path to this directory.
- Download[2] and install Miniforge.
- Open the Miniforge Prompt application.
- Change the directory to the path of the local repository. For example
cd user/git/tygronai/
This directory should contain the tygronai.yml file. - Create and initialize a new Conda environment with the tygronai.yml file using:
conda env create -n tygronai -f tygronai.yml
and press enter to confirm. - Wait for the downloads and unpacking to complete.
- Activate the create tygronai environment using:
conda activate tygronai
The prompt should now display (tygronai) instead of (base). - Start the Jupyter Notebook application by typing:
jupyter notebook
- A browser will open with the Jupyter Notebook application.
- The application should open in the tygron ai repository folder. If not, browse to the folder of the tygron-ai-suite repository.
- Once in the correct folder, select the "example_config.ipynb".
- Adjust the following parameters:
trainDirectory = "PATH TO TRAIN FILES"
testDirectory = "PATH TO TEST FILES"
to the folders containing the exported datasets. See how to export AI datasets for more information. - Press the double arrow button named Restart kernel and execute all cells to run the Jupyter Notebook. See the images below of what to expect.
- Eventually an ONNX file will be created.
Training Considerations
There are some things to consider:
- To train a better model, increase the number of trained epochs, for example to 10:
config.setEpochs(10)
Please note that training with too many epochs may not improve the model; it will become too strict.
Applying your own model
Once you have trained your own AI model and exported it to ONNX, you can import this model into your project and apply it using an Inference Overlay.
However, you will first need to create a new project on a different geographical location than this demo project is situated. Please follow the steps of the New Project Wizard.
Once you have created a new (non-empty) project opened in the editor, you can continue with the configuration of an Inference Overlay.
- To do so, drag the ONNX file onto the Tygron Client Application
- With the popup menu shown, select the option: Import as an Inference Overlay. This Inference Overlay should be configured almost automatically.
- Next, add a new Satellite Overlay.
- Next, select the Inference Overlay and for Input A, select the Satellite Overlay
ONNX file popup in the Tygron Client
Input Satellite Overlay
Inference Overlay using the imported ONNX file
- How to export AI Training Data
- How to train your own AI model for an Inference Overlay
- How to detect foliage using an Inference Overlay
- ↑ Cite error: Invalid
<ref>tag; no text was provided for refs namedref-aisuite - ↑ 2.0 2.1 Cite error: Invalid
<ref>tag; no text was provided for refs namedref-Miniforge - ↑ Cite error: Invalid
<ref>tag; no text was provided for refs namedref-NotebookExample - ↑ Cite error: Invalid
<ref>tag; no text was provided for refs namedref-ymlfile
