Foliage height calculation model (Heat Overlay)
Revision as of 14:55, 4 November 2024 by Frank@tygron.nl (talk | contribs)
Knowing where foliage is present and at what height it is situated for each grid cell of a Heat Overlay is important and used in the Shade and Skyview calculation models.
The foliage height for each grid cell can be determined in a number of ways:
The options for determining the foliage height are mutually exclusive. Only one option will determine the foliage height.
It depends on the available data and the use case which option you will choose as a user. When developing future scenarios in which other users can add foliage to unknown location, it is advised to use the Foliage crown factor option.
Rasterization
Regardless of the source for foliage heights, as a preparatory step for the calculations the data is transformed into a rasterized form. The end-result can be accessed via the foliage result type
Foliage Areas
In case you have vector data containing foliage areas with foliage heights, you can import these by following the how-to: How to import foliage height areas.
Foliage Grid Overlays
In case you have a Grid Overlay with Foliage height, you can create a GeoTiff Overlay and use it as a prequel Overlay to configure the foliage height.
Functions
In the case that foliage heights are derived from Functions with a foliage crown factor, a calculation is performed for all foliage in the project. A building is deemed foliage when it meets the following criteria:
The calculation of foliage heights for all grid cells is then performed as follows:
  1. For each grid cell with foliage, the foliage diameter is calculated by multiplying the height of the foliage building with the foliage crown factor. Dividing the diameter by 2 yields the radius.
  2. This radius and foliage height is stored for each grid cell.
  3. For each grid cell i, each surrounding cell j within a search range of 100 meters is checked for a foliage height.
  4. In case the foliage height > 0, and the grid cell i is within range of the foliage diameter of cell j, the calculated foliage height for cell i is based on the distance from the center of the tree and a linear declining foliage height. The linear decline is 1:1 and currently cannot be set to a different decline. See the image below.
  5. The maximum foliage height is eventually stored as the foliage height of that cell.
  6. Additionally, the Bowen ratio is set to 0.4 and the vegetation fraction is set to 1.
  • The decline of the foliage height cannot be changed, it will always be linear.
  • As noted above, the vegetation fraction and Bowen ratio are also changed when the foliage height is set to a positive height. This means it is also set when a GeoTIFF or areas are used to set the foliage height.
  • Warning: The wind factor reduction is very susceptible to variation in foliage heights, leading to significant higher PET values in forested areas. It is advised that this prequel is smoothed with max and average techniques. The original DPRA Heat stress report uses relatively large foliage areas as input.
Foliage areas (Heat Overlay) in the DPRA Heat stress report
