Evaporation m (Water Overlay)
Revision as of 15:43, 28 February 2024 by Frank@tygron.nl (talk | contribs)
Attribute Unit Description
EVAPORATION_M end-time, m An array of values, each pair indicating until what time that period of evaporation will last and what amount evaporates in that period.
File:Evaporation total.png
Image of the evaporation model in the Water Module
  • A maximum of 10.000 values (5.000 pairs) can be defined.
  • Internally each period with amount values are converted to an evaporation rate per second at a particular time in the simulation.
  • The default value is set to 0.125 mm in 2 hours (0.000125 m in 7200 seconds), which corresponds to 1.5 mm per day. This value is derived from the theory described in 2.3 Gewasverdamping[1] in the book Grondwaterzakboekje, which combines the formula of Makkink with a temperature dependent factor[2] (which is approximately linear between 0 and 24 C). Based on the plotted lines, it was selected as an average of march, june and september, for a cloudy rainy day, which corresponds to a heavy rainfall event.
  1. Fig. 2.7 referentiegewasverdamping Gewasfactoren, Bram Bot (2016) ∙ Grondwaterzakboekje, Gwz2016 ∙ Impressed druk en print
  2. Tabel 2.3 Benadering van ΔΔ+γ en γΔ+γ, Bram Bot (2016) ∙ Grondwaterzakboekje, Gwz2016 ∙ Impressed druk en print
