Special Effect
Revision as of 11:44, 27 May 2021 by Rudolf@tygron.nl (talk | contribs)
This article is a stub.
Special Effects are effects that can be added to a model to make it more realistic. They are visual additions to the 3D world.
Special effects and particles
Special Effects consist of particles, which are the actual visual elements as displayed in the 3D world. A Special Effect is a collection of one or more of such particles.
Particles
All particles are wholely defined by their visual appearance. Some particles are static, and will always display the same way. Other particles can be affected by environmental factors, such as wind direction.
The following particles are available:
| Name | Description | Environment |
| Chimney Smoke (Large) | A thick, near opaque smoke as from an uncontrolled fire. | Affected by wind direction. |
| Chimney Smoke (Medium) | A some effect as from an oversized bonfire. | Affected by wind direction |
| Chimney Smoke (Small) | A smoke effect akin to a smoldering object on the ground. | Affected by wind direction |
| Explosion | A small, periodic, shooting flash. | |
| Light (Red) | A flashing red light. | |
| Light (Yellow) | A constant downward illumination, such as for a streetlight. | |
| Oil Flames | A continuous fire effect with some smoke. | Affected by wind direction |
| Shockwave | Red concentric circles continuously emanating from a central point in a flashing fashion. |
