Watershed Module overview
Overview
The watershed module calculates watersheds for rainfall based on a DTM or a calculated flow direction result of a Water Overlay. The watershed overlay can provide an indication into which waterway or -body rainfall will end up. Users can assign and group waterways and -bodies using discharge areas as input data. Additionally, culverts that connect waterways and bodies can be taken into account, which enables connected waterways and -bodies to be automatically assigned to the prioritized client-provided discharge areas.
Input
Options
  • Discharge remaining water: Create additional discharge areas for waterways and bodies that are not connected by culverts to discharge areas.
  • Minimal area: Only waterways and bodies with the required minimum size can become an additional discharge areas.
  • Discharge method:
    • Height minima: Restricted to height map input data
    • Water terrains: Restricted to directional data. Each water body is a separate discharge area.
    • Specific areas: Restricted to directional data. Provided discharge areas are prioritized and set as input for watersheds. Water bodies that are connected by culverts to discharge area water bodies are assigned to that discharge area as well. Depending on the option "Discharge remaining water", the remaining water bodies are stored as a separate discharge area.
  • Fill distance: unmatched cells are assigned to nearest watershed when within the provided distance.
  • Culvert flow direction: When active, a water body is only connected to an other water body when the first flows to the second.
  • Limit road: When active, the operation that assigns unmatched cells to the nearest watershed within the provided distance locally stops on cells that are roads.
Result Types
