Result type (Watershed Overlay)
The Watershed Module of a Watershed Overlay performs complex calculations and multiple types of results can be provided.
It is currently only possible to add result child overlays via the configuration wizard, in the step regarding output overlays.
List of Result Types
  • Result child overlays are not (re)calculated if either they or their parent is set to inactive.
  • If a calculation overlay is removed, all result child overlays of that overlay are removed as well. Separate overlays set as child overlays (such as input overlays) of the overlay will not be removed.
  • Although it is possible to duplicate the overlay, and set the copy of the overlay to a different result type, we strongly advice to use child overlays instead. Downsides of the duplication approach are:
  1. the simulation has to run in full multiple times, causing a severe increase in calculation time.
  2. When changes to the overlay's configuration have to be made those changes need to be made to all watershed overlays.
API Endpoints
