How to add and remove Net Loads
Editor → Current Situation (Ribbon tab) → Networks (Ribbon bar) → Show Loads (Dropdown)
The left panel for net loads in the editor.
The net load overview automatically groups loads by Net Cluster, "Roots" (root loads), or "unclustered". Within these clusters, the net loads are then grouped by Net Type (i.e. HEAT, GAS, etc).
How to add a net load:
  1. Select the desired Net Type.
  2. Select "Add Load".
How to remove a net load:
  1. Select the cluster the net load is in (or Roots or unclustered if the load is a root or unclustered).
  2. Select the specific net load you wish to remove.
  3. Select "Remove".
