Demo Rainfall Project FAQ
FAQ
Why does water puddle up in any particular location?
Water is affected in subtle and less subtle ways by a large number of factors: the slope of the terrain, the roughness of the ground, the amount of water and the direction it moves in, just to name a few. It's difficult to provide a single answer to intuitively explain all phenomena you may see in regards to water flow and retention. What does help is to look for signs that water is flowing towards or away from any place you wish to inspect more closely, and to take into account continued precipitation, evaporation, and infiltration (although infiltration is explicitly disabled for this demo). More information on water flow:
Why can't I apply spatial actions in any particular location?
The Tygron Platform automatically tests whether a spatial action is even possible, based on (among other things) ownership and current usage of land. If any particular location already has a building, it must first be demolished before a new building can be placed in the same location. E.g., to place a park where there is currently a garden, the garden must be removed first. The land must also be yours to build on. From the perspective of the municipality, plenty of open land is available, but it is not possible to claim or destroy the property of other stakeholders without their consent. More information:
Are there more options for mitigating the effects of rainfall?
Two options to affect the calculation are currently available. In reality (and in the Tygron Platform), more spatial actions exist such as the construction of levees, raising or lowering terrains, or upgrading existing buildings to include water storage. Additionally, it is also possible to change the attributes of parts of the calculation (like the weir heights), such as pump capacities, initial or intended water levels, or sewer capacities. More information on mitigations:
How does any particular setting affect calculation time?
Rainfall is calculated through a series of steps across the entire project map. This makes it difficult to provide a perfect description on how to fine-tune the calculation time for arbitrary projects, although some general rules-of-thumb exist. Setting a longer simulation time, having more bodies of water in the project map, and a more accurate grid size to perform the calculations on, will require more time to compute. Reducing the accuracy, excluding irrelevant sections from the calculation, and limiting the amount of calculations running in parallel are common ways to speed up the computation. More information on calculation times:
How detailed are the performed calculations?
The project is configured with a grid size of 2m. This means the entire project map is divided up into cells of 2m by 2m. Each cell has discrete properties based on the present features, such as a single terrain height and a single water height. For most calculations, this is a high enough accuracy to calculate with, as only the effects of features smaller than 2 meters may be diminished. In timesteps of less than a second per step, calculations are performed for each cell on how much water can move to other cells. More information on grid calculations:
