Api session event editor specialeffect
API Endpoint: api/session/event/editorspecialeffect/
API Endpoints for Special Effect editing.
Name Description
add Add a new Special Effect at a location with an optional Particle Emitter
duplicate Duplicate existing Special Effect
remove Remove existing Special Effect
set_active Set a Special Effect active
set_name Set the name of a Special Effect
Additional API Endpoints:
Name Description
add_particle_pair Add a new Particle Emitter to a Special Effect
duplicate_pair Duplicate a Particle Emitter Pair for a Special Effect
remove_particle_pair Remove a Particle Emitter Pair from a Special Effect
set_location Set the location of a Special Effect
set_particle_pair_location Set the offset (x is east, y is up, z is north) for a Particle Emitter Pair of a Special Effect
set_particle_pair_type Set the Particle Emitter for a Particle Emitter Pair of a Special Effect
