Api session event editor specialeffect set particle pair location
API Endpoint: api/session/event/editorspecialeffect/set_particle_pair_location/
Description: Set the offset (x is east, y is up, z is north) for a Particle Emitter Pair of a Special Effect
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect
1 REQUIRED (Integer number) Particle Emitter Pair ID
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) XYZ-values
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
 body: '[ 1, 1, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/", options)
