Api session event editor specialeffect add particle pair
API Endpoint: api/session/event/editorspecialeffect/add_particle_pair/
Description: Add a new Particle Emitter to a Special Effect
| 0 | REQUIRED | (SPECIAL_EFFECT Integer ID) | Special Effect |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/add_particle_pair/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/add_particle_pair/", options)
