Api session event editor specialeffect duplicate pair
API Endpoint: api/session/event/editorspecialeffect/duplicate_pair/
Description: Duplicate a Particle Emitter Pair for a Special Effect
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect
1 REQUIRED (Integer number) Particle Emitter Pair ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/duplicate_pair/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/duplicate_pair/", options)
