Api session event editor levee
API Endpoint: api/session/event/editorlevee/
API Endpoints for Levee editing.
| Name | Description |
| add | Add new Levee |
| duplicate | Duplicate existing Levee |
| remove | Remove existing Levee |
| set_name | Set the name of a Levee |
Additional API Endpoints:
| remove_side_function | Remove the side Function configured for a Levee |
| remove_top_function | Remove the top Function configured for a Levee |
| set_angle_degrees | Set the slope angle of a Levee |
| set_default_height | Set the default height of a Levee |
| set_default_width | Set the default width of a Levee |
| set_description | Set the description of a Levee |
| set_image | Set the image of a Levee |
| set_is_fixed_size | Set the Levee to a fixed width |
| set_is_relative_increase | Let the Levee raise land relatively instead of a particular datum height |
| set_side_function | Set the Function placed on the sides of a Levee |
| set_top_function | Set the Function placed on the top of a Levee |
| set_use_existing_function | Let the Levee retain existing Functions when applied |
