Api session event editor levee remove top function
API Endpoint: api/session/event/editorlevee/remove_top_function/
Description: Remove the top Function configured for a Levee
0 REQUIRED (LEVEE Integer ID or multiple integer values in array [1, 2, 3]) Levees
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/remove_top_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorlevee/remove_top_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorlevee/remove_top_function/", options)
