Api session event editor levee set is fixed size
API Endpoint: api/session/event/editorlevee/set_is_fixed_size/
Description: Set the Levee to a fixed width
0 REQUIRED (LEVEE Integer ID) Levee
1 REQUIRED (true, false) Is Fixed true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_is_fixed_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_is_fixed_size/", options)
