Api session event editor levee set top function
API Endpoint: api/session/event/editorlevee/set_top_function/
Description: Set the Function placed on the top of a Levee
0 REQUIRED (LEVEE Integer ID or multiple integer values in array [1, 2, 3]) Levees
1 REQUIRED (FUNCTION Integer ID or multiple integer values in array [1, 2, 3]) Functions
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_top_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_top_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_top_function/", options)
