Api session event editor levee set image
API Endpoint: api/session/event/editorlevee/set_image/
Description: Set the image of a Levee
0 REQUIRED (LEVEE Integer ID or multiple integer values in array [1, 2, 3]) Levees
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Image Names
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Image Name 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Image Name 1", "Image Name 2", "Image Name 3" ] ]'
JavaScript example POST
 body: '[ 1, "Image Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_image/", options)
