Api session event editor indicator
API Endpoint: api/session/event/editorindicator/
API Endpoints for Indicator editing.
Name Description
add Add a new Indicator with a default Excel Sheet
append_attribute Appended to existing Indicator numeric Attribute value
duplicate Duplicate existing Indicator
remove Remove existing Indicator
remove_attribute Remove numeric Attribute from Indicator
set_active Set whether an Indicator is active (recalculated and visible to Stakeholders)
set_attribute Set Indicator numeric Attribute value
set_attributes Set multiple Indicator numeric Attribute values
set_color Set the color of an Indicator
set_name Set the name of an Indicator
Additional API Endpoints:
Name Description
excel_min_log_time Set the minimum time for a performance entry to be recorded in an Excel Sheet Call Tree
export_debug_excel Export an Excel Sheet, populated with data related to the Indicator, to Byte array content
export_excel_call_tree Export a performance report of an Excel Sheet, populated with data related to the Indicator, to text as Byte array content
remove_stakeholder Remove the association to a particular Stakeholder from an Indicator
set_absolute Make the score of an Indicator absolute, extending the allowed range. (Relative score must be between 0 and 1)
set_description Set the description of an Indicator
set_excel Set the Excel Sheet used by an Indicator
set_image Set the image of an Indicator
set_parent Set a parent Indicator for a specified Indicator, making it a subselectable Indicator. An Indicator that already has a parent cannot be assigned as a parent to another Indicator
set_short_name Set the short name of an Indicator
set_stakeholder Assign an Indicator to a particular Stakeholder
set_target Set a target value of an Indicator for a Scenario. A target index value is required
set_update_timing Set the calculation Timing of an Indicator
swap_order Swap the order of paired Indicators
