Api session event editor indicator set parent
API Endpoint: api/session/event/editorindicator/set_parent/
Description: Set a parent Indicator for a specified Indicator, making it a subselectable Indicator. An Indicator that already has a parent cannot be assigned as a parent to another Indicator
| 0 | REQUIRED | (INDICATOR Integer ID) | Indicator | |
| 1 | REQUIRED | (Integer number) | Parent Indicator ID (use -1 if no parent exists) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_parent/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_parent/", options)
