Api session event editor indicator set stakeholder
API Endpoint: api/session/event/editorindicator/set_stakeholder/
Description: Assign an Indicator to a particular Stakeholder
0 REQUIRED (INDICATOR Integer ID) Indicator
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_stakeholder/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_stakeholder/", options)
