Api session event editor indicator excel min log time
API Endpoint: api/session/event/editorindicator/excel_min_log_time/
Description: Set the minimum time for a performance entry to be recorded in an Excel Sheet Call Tree
| 0 | REQUIRED | (Integer number) | Time in milliseconds |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '32'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '3'JavaScript example POST
body: '32'
fetch("https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/", options)
