How to detect foliage using an Inference Overlay
Revision as of 09:54, 18 November 2026 by Server@tygron.com (talk | contribs)
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar)
How to detect foliage based on an Inference Overlay:
  1. First add a Satellite Overlay. This will be used as input for the Inference Overlay.
  2. Add an Inference Overlay
  3. With the Inference Overlay added and selected, click on Select Neural Network.
  4. In the selection panel, select the RCNN named foliage.onnx and click select.
  5. Now select Use A (Input A:RGB) and select the previously added Satellite Overlay.
  6. Make sure the Grid cell size is between 25-50cm, can be adjusted by selecting (Change Grid).
  7. Finally select Update Now and see the results.
