Api session event editor levee
Revision as of 10:26, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorlevee/
API Endpoints for Levee editing.
Name Description
add Add new Levee
duplicate Duplicate existing Levee
remove Remove existing Levee
set_name Set the name of a Levee
Additional API Endpoints:
Name Description
remove_side_function Remove the side Function configured for a Levee
remove_top_function Remove the top Function configured for a Levee
set_angle_degrees Set the slope angle of a Levee
set_default_height Set the default height of a Levee
set_default_width Set the default width of a Levee
set_description Set the description of a Levee
set_image Set the image of a Levee
set_is_fixed_size Set the Levee to a fixed width
set_is_relative_increase Let the Levee raise land relatively instead of a particular datum height
set_side_function Set the Function placed on the sides of a Levee
set_top_function Set the Function placed on the top of a Levee
set_use_existing_function Let the Levee retain existing Functions when applied
