Api session event editor cinematic
Revision as of 10:26, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorcinematic/
API Endpoints for Cinematic editing.
Name Description
add Add a Cinematic for a Stakeholder
duplicate Duplicate existing Cinematic
remove Remove existing Cinematic
set_name Set the name of a Cinematic
Additional API Endpoints:
Name Description
add_keypoint Add a Key Point to a Cinematic
add_keypoint_event_bundle Add an Event Bundle to a Key Point of a Cinematic
add_keypoint_with_parameters Add a Key Point with the provided camera location, orientation and lookat in 3D Visualization coordinates (X is east, Y is up, Z is south)
duplicate_keypoint Duplicate a Key Point of a Cinematic
move_keypoint Move a Key Point to an index of the array of Key Points of a Cinematic
remove_keypoint Remove Key Points from Cinematics
remove_keypoint_event_bundle Remove an Event Bundle from a Key Point of a Cinematic
set_keypoint_description Set the description of a Key Point of a Cinematic
set_keypoint_orientation Set the camera location, orientation and lookat of a Key Point in 3D Visualization coordinates (X is east, Y is up, Z is south)
set_keypoint_paused Let the Key Point of a Cinematic pause the Cinematic once it is reached
set_keypoint_time Set the time it takes to move from the specified Key Point of a Cinematic to the next
set_voice Set the voice used for text-to-speech of Keypoint descriptions of a Cinematic
