Api session event editor cinematic duplicate keypoint
API Endpoint: api/session/event/editorcinematic/duplicate_keypoint/
Description: Duplicate a Key Point of a Cinematic
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic Data | |
| 1 | REQUIRED | (Integer number) | Key Point ID |
| 200 | Integer (Key Point ID) |
curl 'https://engine.tygron.com/api/session/event/editorcinematic/duplicate_keypoint/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/duplicate_keypoint/", options)
