Api session event editor cinematic set keypoint description
API Endpoint: api/session/event/editorcinematic/set_keypoint_description/
Description: Set the description of a Key Point of a Cinematic
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Data
1 REQUIRED (Integer number) Key Point ID
2 REQUIRED (String) Description
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Description" ]'
JavaScript example POST
 body: '[ 1, 1, "Description" ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_description/", options)
